Try these, they work in mine.
That...is brilliant!If you leave one regular bulb on the dash light circuit, the LEDs will dim reasonably well. It could be the bulb in your radio. I left incandescent bulbs in my aftermarket gauges.
Do they need additional resistors or anything?Try these, they work in mine.
(image removed)
No additional resistors needed. I left my front turn signals as incandescent, so I didn’t even need to change the flasher. The turn signals work the same.That...is brilliant!
I've been busy on My car i'll get the pic on here shortlyCAn you post a picture of what your bulbs look like?
I only have them in the cluster illumination. The blinkers,high beam indicator,the brake and oil warning still have the regular glass i think its a 194I've been busy on My car i'll get the pic on here shortly
the bottom is like the glass ones and even tho I did ordered them on e-bay all of them worked and they r polerised if it don't light turn it around and it will .For the price I'm happy I thint I paid about a 1.00 to 1.50 each anyway here the r
