Spray some Kroil on the drain plugs and let it sit for a day
the only difference pulling the bottom hose makes vs draining at the radiator tap is speed. oh and mess, lol. the end coolant level in the motor will be the same. so fast drain but longer clean up time or slow drain and little to no clean up time. your choice.I've always pulled the lower hose off as it drains the coolant quicker, it won't drain the block entirely but it will bring the coolant level below the water pump ports, true or false?
Thanks for the input! I don’t see enough of this stuff to notice that level of detail. I am trying to learn as much as I can.Nice heavy duty pushrods and someone spent some time on that block deburing the center drain back holes.
I am not disassembling the motor, just replacing the intake manifold. So I wasn’t planning to remove the anything. Here is a few other shots.Looks like adjustable rockers? Pushrods are ball/cup. A further back shot would help id stuff. Take out pushrods and lay cloth/rags down. Keep pushrods and lifters in order/numbered.
paper towels. i have a GIANT roll of the heavy blue towels (thanks U-line!) and they work great. i lay those down in the valley and then lightly stuff the ports so nothing drops in there.What do you guys use to cover the lifter valley while I clean the intake gasket area to keep all the junk out?
Air Gap knock off.I probably missed it but what intake are you using. Leave your rags in the valley and carefully work that back and forth with vice grips.
If you feel capable gasket match it to your heads.Air Gap knock off.
I get my gaskets later this afternoon. I’ll look at all the matches.If you feel capable gasket match it to your heads.
