dodgethis12
- Joined
- Feb 9, 2010
- Messages
- 93
- Reaction score
- 0
Ok so since I dropped the heads off at the machine shop and the valves were basically welded to the heads from varnished gas... the older guy at the shop said you need to replace the entire fuel system...
I figured I would listen
SO I dropped the tank and sure enough the inside of it is completely full of crust and varnish.
Heres what I need:
New tank
New line from tank to front of car
new sending unit
new rubber seal for tank filler tube.
I know that inline tube.com has the lines....
Are there any other better places to get the lines? WHeres my best source for a tank and sending unit?
And lastly anybody know if I can find a rubber ring that seals the filler tube to the tank?
Thanks
Edit: 70 swinger 2dr 318 auto.
Heres what I need:
New tank
new sending unit
Thanks
