Make certain the springs are not sprung or unsprung and not all rusted up and they should be good to reuse Make certain they are seated in the groove before you walk away from em. Dab some grease in the socket when your done so as to prevent premature rusting. Good luck.
Small Block
yea, id get new ones. i like the urethane boots, gotta get them soft in boiling water, then spray em with silicon spray and they should slip on the new torsion bars.
