318MoparGuy
MoparHokie
Hi All,
My repro LED (I didn't install it and PO has no paperwork on it) hood tach started acting up when my alternator went south on way home....the needle was bouncing back and forth like a ping pong ball until the battery ran out of juice.I replaced the alternator and voltage regulator and the system is charging properly now, but the hood tach is not giving a true reading of the engine RPM's...it barely moves off zero when idling...before it sat at 800 RPM's at idle. Does anyone recognize this model/brand (see photo) and can it be reprogrammed or be reset to make it functional again? Thanks in advance for any and all help.
Greg
Greg
