Every 318 I ever had with that single plane 2b carb, had a steel crank, I would not toss that motor too fast.
Yeah. Didn't need it. Gave it to a buddy of mine.Every 318 I ever had with that single plane 2b carb, had a steel crank, I would not toss that motor too fast.
Yep. Took longer than I thought to get just that one panel out. A drill,hammer, and pry bar were my tools of choice. Bought a spot weld cutting bit, will see how that works this weekend.I see alot of drilling spot welds in your future.
and sometimes before . I got my trunk floor out without so much as cutting a thing, just the chisel. But for sure a handy tool to have. I used a cheapy Harbor Fright one. like 7 bucks but it did the jobI would also buy an air chisel, makes it easy to pop the sheet metal apart after drilling.
Where'd you get the panelWell... went to put the panel in the car today. Began to weld it. Something in the house blew out. Now the front half of the house doesn't have power. Reset all the circuit breakers. Still nothing. It's always something .
AMD.Where'd you get the panel
