Divenut
OK brake gurus,
Finally got some time to plumb the new brake lines on the Duster. 72, Wilwood front disc/rear drum combo, new MC, Wilwood proportioning valve.
Adding a 10lbs residual pressure valve to rear drum line. Per Wilwood, it needs to be as close the MC as possible, and before the proportioning valve.
In an effort to minimize splices/conections, I'm thinking about screwing it right into the MC versus downstream. Inline. Any problem screwing it directly into the MC rear line port?
Thanks in advance,
Pat
Thanks in advance,
Pat
