K keith Member Joined Aug 19, 2011 Messages 13 Reaction score 0 Location Windsor Ontario Sep 18, 2011 #1 hooked up a chrysler electronic system,car fired up and ran no problems,last weekend . Now my resister is heating up any one have this problem???
S skykeith Well-Known Member Joined Dec 16, 2009 Messages 236 Reaction score 46 Sep 19, 2011 #2 the ballast resistors get very hot. If you look at it , you'll see an air gap between the resistor and it's mounting surface. You can install a washer between the resistor and mounting surface to give it a little more airflow, but hot is normal.
K keith Member Joined Aug 19, 2011 Messages 13 Reaction score 0 Location Windsor Ontario Sep 23, 2011 #3 thanks keith
