Mark Nixon
Senior Moments Member
I've done this into a '68 Dart.
The biggest trick is getting the stock wiring harness for the Magnum EFI all sorted down to a manageable system.
The crate engines would be a bit of a trick to do the EFI, as they don't have the same balance as a Magnum engine and the stock EFI for a Magnum REQUIRES a flywheel with the tone ring on it to work.
I was going to offer the wiring on a by-order-basis, but there seems to be no interest in it.
BTW, pre-'97 Magnum PCMs are NOT reprogrammable!!!
Mark.
Mark.
