Ok, thanks for the info Trail Beast.
Permatex Ultra Black RTV Silicone 82180 this is the RTV I'm using.
Yep, the Ultra series of RTV comes off even easier than the normal RTV.
IMO people that just run down and get a new gasket either have money to do that all the time, or no experience with what the requirements of the gasket are.
That's why I said it's a personal decision, to get new ones or not.
Also note that where the china wall, heads and intake come together on the passengers side the china wall comes real close to not actually meeting up with the underside of the intake in that corner.
I like to have everything in place and ready and do the china wall last fast and wet when the intake sets down.
The Right Stuff or Red RTV is all I will use on an intake, as like I said the Ultra series RTV is a lot softer when set.
A heavy 3/8 bead front and back staying close to the inner side of the wall is the trick.
Especially on that passenger side front corner.
Then slam that intake on there as soon and as straight down as possible.
RTV the bolt threads, and a small bead under the shoulder of the bolt head where it will contact the intake, then wipe off any that squeezes out from under the bolts right away.
You will have a nice clean assembly that won't seep oil on your intake, heads and block.
