Howdy gang, cosgig here! With Dels help, I am amending this thread to correct the item I really need!! The part I need is the reverse light trigger switch that mounts to the shifter mounting bracket and turns on the revers light when the shifter is in the reverse position!!! I assume they are all the same between years, but for reference it will be going on a 66 Valiant! Either used or a lead on where to buy them new would be most appreciated!! Thanks people, Geof
Pic of current "setup", found under the carpet!!
