512Stroker
We are all here because we are not all there.
All these parts are factory originals and came from a 340 X head engine date coded in 1969.
All parts are used and need some restoration/repair but appear to be in fair/good shape. A quick inspection showed some signs of normal wear, but no obvious cracks or severe damage that would make them unusable.
All prices shown do not include freight, if you commit to the purchase of a part/parts I will box them up and and get actual shipping costs from USPS and that's you will pay plus the cost of the part.
The first" I will take Item -" will win the item please follow up with a PM to me.
Payment is via USPS MONEY ORDER ONLY. Please no PayPal or checks of any kind. Will consider partial trade for a Carter AVS 4966 carb.
Thanks for looking
Item 1 - LA small block valve covers with correct crankcase vent can. These covers need restoration one or two bolt holes need repair. - $75
Item 2 - Cast iron hi-rise 340 Intake manifold P/N 2581915-2, just needs good cleaning - $120
Item 3 - Factory LA small block exhaust manifolds with heat riser butterfly which moves freely. These are in very good shape. - $150
Item 4 - Factory stock 340 (stock bore) size pistons with pins and new ,never run rings. Ring manufacture is unknown. These piston show normal wear but are in serviceable condition, good for a econo build should produce 10.5 to 1 compression with X heads. - $100
Thanks for looking
