67 gt
A Wog boy who loves his Mopars !
Hi all looking for some advice,first a run down on my 318 that im building its a LA 74 block,which is Zero decked,40 up ,torque plate was used in the honing process,main bearing caps were lined honed, ARP mains bolts,balanced,steel crank 10 under on mains and big ends,scat i beam rods with the 7/16 arp bolts used & with bushings in the small end to accommodate the full floating pistons KBs 167s pistons,Moroso windage tray,new std pump with stronger relief spring as im using std sump.The cam is a comp cams 270s solid,Duration @ .50"lift 224, valve lift 468,lobe sep/110,comp solid lifters,pushrods and pro mag roller rockers,1406 Edelbrock vac secondary carb.Now some advice needed on these cylinder heads im looking at they are the RHS 62cc with the 192 intakes,162 exhaust stainless valves,10 degree retainers with locks.Springs will be the comps 901 singles with dampers,Are these heads the large port design or small port?as i have the LD4B manifold which i would like to use and i have the headman block huggers ceramic coated small port,could these items still be used?would these heads be a bit of a over kill due to the larger size valves.The car wont see a drag strip but will be opened up on occasions but mainly cruzin.Running a 904 havent decided yet on converter,with 3.55 rear end gearing.Any advice would be appreciated.Thanks in advance
