right angle oil filter adaptor gaskets?????
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
the p o took it apart, I gotta put it back. question: I have complete engine gasket kit, is there a gasket on each end of the hollow bolt. ?? I have what appears to fit inside that is cork and one that fits the outside that's a stiff thin gasket. thanks for any insight...
I do have the one for the perimeter of adaptor.
If I recall...These have a thin metal washer that installs under the head of the hollow bolt, that's it. These also have a gasket, gasket goes between 90Deg and the block. I have used the gasket from the carb to air cleaner, it was the same size!
I think this is what your looking for in an answer?
Under the head of the hollow bolt there should be a washer made of copper I think. Under the adapter there should be a large ring on the outside and around the bolt there should be a small ring gasket.
This is what you should have, I'm not positive on orientation.
