Rim blow adapter Question:
moparhunter
I picked up a Rim blow ( fake wood/ three spoke ) wheel that I’m putting on my 69 Dart - Is there more then one size ( out side round diameter) adapter, the one I have is probably a inch “Rounder “ then the column - I think I know the answer asking for a friend
The column itself changed in 1970 when they moved the key from the dash, into the column. That is why the column is a larger diameter in 1970 and up cars. I don't believe the rimblow was available until 1970.
You need the newer collapsible column to make it fit right. 1970’ and up.
The other option is if you have a machinist buddy- have them fabricate you the correct adapter.
