RockAuto Question
pacuda59
pacuda59
Pennsylvania
When I ordered hoses for my brakes, Rock automatically sells you two per order although it's not very clear on their site. I need to order new bearings for the rotors I pulled off of a 75 Dart. Rock lists the inner and outer bearings of which I need one of each per rotor. My question, when I put an inner bearing in my basket and the quantity ordered says 1, are they sending one inner for each rotor or just one for the left rotor.
Thanks, last time I called Rock I was on hold for 20 minutes.
I just ordered rotors, calipers, pads, inner and outer bearings and seals from Rock Auto for my Aspen and I ordered 2 of everything and that is exactly what I got. I saved $30 over local parts stores even including their inflated shipping cost! I agree with Motopsycho though if I were just buying bearings and seals I would buy locally.
You need 2 - set17 and 2 -set2 bearings to do a complete front.
Don't forget a 5% discount code. 1626921813431413
