skrews
Great picture Skrews. One suggestion - if you could label them as to the manufacturer it might help some guys in initial buying.
These are std. offset big block rockers. I used this pic to illustrate the poor design work of most aftermarket rockers out there. The situation is the same with small block rockers.
Left to right Comp, Indy, Hughes, Harland Sharp, Crane, CAT aka junk.
