Thanatos340
First time engine builder here. Actually Assembler is more accurate. I bought a crate 408 short block and doing final assembly.
I had everything assembled and went to spin up oil pressure using a drill and noticed I was not getting any oiling at all to the rocker arms. Engine was spinning up 80psi oil pressure on the stand using the drill and nothing at all to the rockers. I pulled the rockers on one side and tried again and still nothing. Pulled the Head and nothing. Shouldn't I be getting oil from the Hole I marked below if I have 80llbs oil pressure?? Am I missing something here or is there most likely a blocked oil passage somewhere?
