73Scamp318
A little background on the combo first...
The car is a '73 Plymouth Scamp.
318 .030 over
about 10.5:1 CR
Comp 282 Solid 236*@.050, .495 gross lift
Victor 340 single plane intake
J heads rebuilt/ported by Aerohead (Indy)
1 5/8" headers to 2.5" duals
9.5" PTC converter (brake stalls @ 3500+)
3.91 gears
M&H DOT 26" bias plys
I pulled the valve covers off of my small block the other day to readjust the valves as they've been getting noisier lately. Just for kicks, I decided to pull the rockers off to check them out.
I've been using an old set of 273 rockers for quite some time now and they weren't in the best shape when I put them on. The rockers and shafts are now shot, both are galled pretty bad.
I'm looking at investing in a new set of rockers and shafts, possibly hold-downs, and would like some input. I've considered picking up another set of iron rockers, but the cost winds up being right in-line with roller rockers. I've pretty much narrowed it down to Racer Brown, Hughes, or Comp rockers.
I'm also trying to decide whether to go with 1.5 or 1.6 ratio rockers. The valve springs that are on it are good to .550 lift, so either should be okay.
So, any input or additional options? The car is about 50/50 street/strip and I would like to get at least a few years out of the rockers. I probably only put less than 5,000 miles on the car a year.
Thanks for any input and the great site! :thumleft:
318 .030 over
about 10.5:1 CR
3.91 gears
