Sorry I should have said "Better Than Stock" I have some from an old 340 here.Rock Auto, but like so many things right now, it's currently out of stock.
More Information for ENGINETECH HK108 (rockauto.com)
Might be able to use the part number to source the kit elsewhere, though.
Or something from Summit.Sorry I should have said "Better Than Stock" I have some from an old 340 here.
But hate to use them.
422" stoker 10.88 to 1, Eagle Crank & H Beam Rods, Diamond Custom Pistons, Custom Ground Solid Cam, Ported Edelbrock Heads, Comp Cams 1.5 Roller Rockers.
All ARP, would just get studs but they just show Studs no Hold Downs.
Hughes shows out so does Mancini on the Hughes.
Rocker Shaft Hold Downs
So asking what Brand Type? Thanks
The kit I linked is for the cam plate bolts and associated hardware, not the shaft hold downs.Sorry I should have said "Better Than Stock" I have some from an old 340 here.
My last set of Mopar were junk.I like how the aluminum ones caress the shafts and I have room to etch the position on the tops of them. I usually keep a spare set handyView attachment 1715982986View attachment 1715982987
Harland Sharp is in stock at Summit and may or may not come with bolts. But was going Studs Description states steel but later on says aluminium. So wonder what they are.
That is what I did. As others were out of stock.The Hughes kit is good. Did you try ordering direct from Hughes Engines?
