GTSDustin
I know there is a right and left rocker shaft, but can't remember which is which.. Can anybody tell me which way the "notch" goes? Thanks in advance
weren't both shafts actually the same part, just one side installed with the notch down at the front, and the other notch installed down at the rear?
Correct, same part. visualize it in your mind with you in the drivers seat, if you turn the DR shaft 180 end for end the notch will now be at the rear and the offset holes will be still kicked outward toward the fenderweren't both shafts actually the same part, just one side installed with the notch down at the front, and the other notch installed down at the rear?
These are called siamese heads. Either fits left or right bank, just turned end to end.
Exactly. There is no right or left head and so the shafts fit the heads exactly the same way, they are just turned the other direction.
