Rockers
Looks cool but once the valve cover is on….
They disappear. Ask RRR. He will know if they are worth the money or not.
I have a set of roller rockers for the slant. Bought used, but look like new, for a great price. Not sure of the brand, or ratio. I think they are a set of the Cox Bros rockers, which were made by RAS. One of these days I will check out the ratio.
I reckon it depends on what you're doing. It's been proven time and again that roller rockers don't add power.....UNLESS it's through correcting the factory ratio that's really not very accurate. I guess the 1.6 ratio could add some power, but IMO it's better to just choose a cam with the lift you want and run the 1.5. IMO the only real advantge would be the true ratio and roller rockers all but eliminate valve guide and valve stem wear. Those are decent advantages, but I reckon only you can decide if that's enough. I'm not sure it would be for me. I think that set is a good bit past a thousand dollars.
