busted knuckles
- Joined
- Dec 10, 2006
- Messages
- 231
- Reaction score
- 0
I need to replace a rod bearing in my 225. I took it apart to check for a spun bearing, the top half of the bearing moved when I replaced it and tightened it down, I squished the tab that keeps it from turning in the process. I have never fit a bearing before. Will I have to possibly file the end of the bearing to get the correct clearance? Also, will I need to replace with same brand of bearing? This was stamped on the back ACL 020 4601 30JL99
