Nobody that I know of.Shut the key off. That’s why they put them in cars. No performance cam of any kind should sit and idle for 45 minutes. Who does **** like that?
All the parents picking up kids at child’s school. Just curious if I could do it in an old Mopar. In San Antonio, the parents at our school sometimes wait for two hours-yes of course in modern cars, just wondering if I possibly could with a solid roller if I had to.Shut the key off. That’s why they put them in cars. No performance cam of any kind should sit and idle for 45 minutes. Who does **** like that?
Yes dammit yes. How many times do you need to read it?All the parents picking up kids at child’s school. Just curious if I could do it in an old Mopar. In San Antonio, the parents at our school sometimes wait for two hours-yes of course in modern cars, just wondering if I possibly could with a solid roller if I had to.
Someone that could sit in line for 45 minutes up to two hours waiting to pick up their little crumb crunchers ain’t got no time to be messing with solid roller cams. Best off getting a minivan and maybe some of those stick family stickers.On the Street? WHat if you had to idle in traffic, say waiting 45 minutes (in idle) to pick up your kid from school (nobody walks home from school anymore)?
The solutions are simple. Make them ride the bus as God intended, or get a better watch and show up at the appropriate time.All the parents picking up kids at child’s school. Just curious if I could do it in an old Mopar. In San Antonio, the parents at our school sometimes wait for two hours-yes of course in modern cars, just wondering if I possibly could with a solid roller if I had to.
You got that right!Someone that could sit in line for 45 minutes up to two hours waiting to pick up their little crumb crunchers ain’t got no time to be messing with solid roller cams. Best off getting a minivan and maybe some of those stick family stickers.
I don’t see a oiling or a mechanical problem with idling on any cam for a long period. If I was picking up the kids as a normal daily thing, it wouldn’t be in a hot rod that uses a solid roller though. If I “Had to”, fine. As an everyday vehicle? The vehicle would certainly be a different vehicle though. Like a mundane grandma driver. That’s not to say it couldn’t be equipped with some go fast parts though! I’d just like an absolute easy driver with a smallish cam, nice idle quality and high vacuum along with a darn good heating and A/C system.On the Street? WHat if you had to idle in traffic, say waiting 45 minutes (in idle) to pick up your kid from school (nobody walks home from school anymore)?
Just wondering if you can help - do you know if these lifters will be suitable for a 360 Magnum engine build?If you havent purchased anything there are options. The lifter bores on magnums are longer in length. If it is a true LA block and you are set on going with a roller set-up I would highly recommend Hughes "Morrel" roller lifters HUG #5321. I put them in my 408 with a Comp Cam hyd roller and the work great. They also moved the oil band on these to accommodate the shorter lifter bores in the LA blocks and allow for pushrod oiling.
There is no reason that your engine could not idle until the fuel tank ran dry....
Engines that do a lot of idling are taxis; the engines generally last longer than most cars because the engines are always at operating temperature.
if you have a magnum block then stock roller lifters will be fine and cheaper.Just wondering if you can help - do you know if these lifters will be suitable for a 360 Magnum engine build?
Thanks but am building a mid performance street/autocross engine. Have heard good things about Morel.If you have
I am building one for my 1965 Dodge Dart with the roller cam.Came out of a 1999 Dodge Ram 2500 which did run good.Yard I bought it from had it in the truck before it was pulled and I heard it run telling them to pull itLate year LA engines are also called “Pre-Magnum” engines. In other words, late year LA engines are roller cam engines that have spiders.
The stock magnum roller lifters will be more than you’ll need.Thanks but am building a mid performance street/autocross engine. Have heard good things about Morel.
A 1999 from a 2500 ram is not a late year LA pre magnum. It IS a magnum.I am building one for my 1965 Dodge Dart with the roller cam.Came out of a 1999 Dodge Ram 2500 which did run good.Yard I bought it from had it in the truck before it was pulled and I heard it run telling them to pull it
Thanks for the correction.A 1999 from a 2500 ram is not a late year LA pre magnum. It IS a magnum.
No rumble you had (and still have) it correct. I quoted you because in her reply she was addressing you and it was pertinent to my response.Thanks for the correction.
Well, I guess I misspoke. Before Magnum engines were the “LA” series engine. In the last few years of the “LA” engine, they were roller cam equipped. The first few years of the Magnum engine, the blocks were still drilled for rocker shaft oiling. I call these blocks “Pre-Magnum” blocks even though they came with Magnum heads.
Post #40Oh! OK, thanks. I thought I screwed up!
I guess I missed her reply then?
