roller rocker arms
moparraceman
mansfield ohio
cant afford the harlam sharp rockers for small block 340 at over $700 a set has any one used the PRO COMP roller tip rockers ? is the quality good ? feed back please thanks
I'm using the Comp Cam Magnum Rockers on 2 different engines for 6 seasons now,very satisfied with the quality and performance..
ProComp or ProForm, they are 1/3 the price of Harland Sharp. You get what you pay for. The cheap stuff is Chinese manufactured. The price of Comp Cams "Magnum" steel rockers is somewhere in between. They make some quality parts. I went with them too, like stroked 340 did.
Comp Cams roller rockers in use here for about 18 years now.
I have set of factory ones with pushrods,let me know if you want more info,mark
Part number 1622-16 they come with the shafts now too..
I have a very low mileage (like 20 and not in 1/4 or 1/8 mile increments either) set of older Comp Magnum rockers, they are a steel body with roller tips, comes with shafts. I bought them new. Message me if interested.
I'm not seeing steel rockers for Chrysler on Comps site. Do they not make them anymore?
Nevermind, thanks for the model #
They still make them. Just bought a set 2 weeks ago.
PRW Stainless and a B3 Racing geometry correction kit. Light years ahead of off the shelf Comps without the kit.
With the PRW's and correction kit, the total cost will be less than Comps.
They make the Pro Magnums and Ultra Pro Magnums. The original Magnums they do not make any more.
