needsaresto
- Joined
- Nov 13, 2004
- Messages
- 7,625
- Reaction score
- 284
Just one thing here needs an answere. Just wondering why stainless? Try to lighten up the valvetrain a little with some alum rockers.
i guess just tryin to find a roller rocker that will handle the lift of my cam.Just one thing here needs an answere. Just wondering why stainless? Try to lighten up the valvetrain a little with some alum rockers.
Those look like they don't have fulcrum bearings? Are they individual shafts for each cylinder like Jesels?
it looks like the kmj ones are goodNo fulcrum bearings, and they are shaft mounted. Very nice set
RAS Roller Rockers as good or better than T&D. http://www.rockerarms.com/
Mopar7172 - couple of thoughts, CompCams has a nice set too, should look at those as well, but they only come in 1.5's. I am a fan of steel /bronze bushed, they are reusable and reliable. Aluminums are good, just more for the race side of the house, you need to keep an eye on them. And, IMO stay away from any that have needle bearings.
And Stokerscamp, got my RAS's, didnt take six months.
I live around the corner from T&D. As someone put it they or the sales person I dealt with was an arrogant @$$, not dropping $1,200 to deal with an @$$ - too found that true when I walked in to talk to them - not doing it
those look like good rocker arms.#1.... What about the latest PRW rockers?
#2.... How much are these?
#3.... Comps still great?
don't have to run 1.6 rockers? i have .564 high xtreme energy comp cam in my 440Like said going with a 1.6 ratio rocker, you're adding lift- be sure to check PTV clearance before starting the engine..
don't have that kind of money to spend on rocker arms. its not drag car also.RAS are about $1,150 shipped. Very nice, as good if not better than T&D
And they are 1.6
whats PTV clearance?Like said going with a 1.6 ratio rocker, you're adding lift- be sure to check PTV clearance before starting the engine..
i'm runnin the probe racing pistons in it...............piston to valve............if u got cast pistons, u prolly wont have enough ptv clearance or retainer to guide clearance............kim.......
flat top.........R ur pistons flat top or do they have a raised area and valve pockets........kim......
