Ron Francis Ignition column wiring
Electrical and Ignition
  1. cuda guy
    cuda guy Well-Known Member
    385
    22
    Oct 15, 2009
    Local Time:
    2:30 PM
    Hi all
    Im having some issues or questions with the RF retro moper wiring kit, my issues stem around the factory column wiring and the RF instructions
    here is my main question
    Can anyone help me with the ignition connector for my 72 dodge dart demon column key
    10 gauge red is power in for the battery
    10 gauge black does what
    10 gauge blue goes to Ballast
    10 gauge brown goes to coil side ballast
    10 gauge yellow goes to starter relay
    18 gauge black goes where orange on the dash side
    2 x 18 gauge red wires go where black on the dash side
    And when I use this wire do I disregard the the brown and orange wire from the fuse box
    Thanks for ur help
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    42,931
    10502
    Oct 14, 2010
    Idaho
    Local Time:
    12:30 PM
    Can you post a link to the Francis documentation? Or take a photo/ scan it and post it here?
    Offhand orange wiring is generally dash dimmer controlled lighting, so that would be your shift quadrant lamp
  3. cuda guy
    385
    22
    Oct 15, 2009
    Local Time:
    2:30 PM
  4. 67Dart273
    42,931
    10502
    Oct 14, 2010
    Idaho
    Local Time:
    12:30 PM
    What I'm getting at is what is it that you think is different with the Francis end? (In other words I have no idea what Francis did) I would guess it is "fairly universal" due to differences in models. Without being able to view the Francis end of the thing documentation, I have no idea. Do you have a factory wiring diagram? (MyMopar.com)
    Here is a shot out of the 72 manual
    The bottom pin by the way is the horn wire, and interfaces with the "key in" buzzer circuit
  5. cuda guy
    385
    22
    Oct 15, 2009
    Local Time:
    2:30 PM
    I understand the above but RF kit has a brown and orange from the fuse box and a red and lgt blue wire leaving
    I think this is for a GM switch
    What should I do just by pass this and use the above or what
  6. 67Dart273
    42,931
    10502
    Oct 14, 2010
    Idaho
    Local Time:
    12:30 PM
    I already told you.........without the Francis end documentation, there is no way to know. So either find a link to the Francis "book" or post the viable section out of the manual that they gave? you, or call / email Francis.
    Sorry,
  7. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    28,973
    9048
    Aug 28, 2009
    Wasting time here
    Local Time:
    2:30 PM
    You got the RF kit, post a RF wiring diagram.
  8. 65 Dartman
    65 Dartman FABO Gold Member FABO Gold Member
    11,246
    2902
    Sep 24, 2006
    Strasburg, VA
    Local Time:
    3:30 PM
    IIRC there is no Mopar-specific RF harness as it is based on GM wiring.
    • Agree Agree x 1
    • RedFish
      RedFish Well-Known Member
      24,175
      2791
      Sep 5, 2007
      Local Time:
      2:30 PM
      Many of the aftermarket replacement ignition switches have a extra smaller gauge black wire in the port where factory had placed the orange wire. Easiest fix it just use male female spade connectors to make up the orange connection beside the main connector. Let that extra black wire dead end where it is. Not all models have or use that extra smaller black wire.
      If anyone has wiring diagrams for F-body, C-body, whatever that shows this 6th wire ( 18 ga black ) coming from ignition switch being used... I would love to learn where it went/what it was for.
    • cuda guy
      385
      22
      Oct 15, 2009
      Local Time:
      2:30 PM
      thanks every one
      But I'm getting it sorted out
