iw378
I just got done taking out all of my old wiring. Anyways I have a couple of questions
They are closed today otherwise I would call them. First question is their instructions say to hook up the fuse panel power, And alt charge wire to the positive post on starter soleniod not the relay. It would be easier to go to the starter relay correct ? or does it make a difference.
Second question. They say to use the ford style regulator If I want to keep my mopar reg. what steps do I need to do?
The brown wire on the right goes to alt field so I would hook that up to the field connection on the mopar regulator ? In the instructions it says to hook up the other end of the brown wire on the left to post 2 on the fuse panel. would that just go to the ign terminal on the mopar reg. Any help appreciated.
I did search and could not find the answers to my questions.
Thanks
Luke
Thanks
Luke
