Hotrod1941
Looking for some tips on removing the roof and window trim on my 65 dart. Having trouble getting it off the drip rails. Trying to get it ready for bodywork. Any help is appreciated.
Try using a small block of wood and a hammer, preferably a hard wood like Oak. Work a little bit at a time on the bottomLooking for some tips on removing the roof and window trim on my 65 dart. Having trouble getting it off the drip rails. Trying to get it ready for bodywork. Any help is appreciated.
Do you mean to tap it underneath on the window side pushing it outwards? These pieces are a real pain. Theres still small pieces of the vinyl roof stuck under this trim so it definitely needs to come off.Try using a small block of wood and a hammer, preferably a hard wood like Oak. Work a little bit at a time on the bottom
edge. Start at one end and move forward. Don't try to remove it fast or you may have trouble. And try to keep from using metal tools, because they will distort and scratch if you slip when using one. They can be a pain. Be patient.
Yes, It has to be released from the bottom. It will be tight if it is over vinyl top material on drip rail. If it is foldedDo you mean to tap it underneath on the window side pushing it outwards? These pieces are a real pain. Theres still small pieces of the vinyl roof stuck under this trim so it definitely needs to come off.
