Rosette rivets
132068Dodge
Arizona
Rating - 0%
0   0   0
Sorry to bring up a topic that no doubt has been brought up many times before, but I need to purchase a set of rosette rivets for my 69 dart project. I know I can use regular rivets but I would like to stick to a factory look if possible. I changed dashes from a 69 to a 68 secondary to rust and for the fact I am building a 68 SS car. I have researched a few sights and they want anywhere from 40- 50 dollars for them. I know its old news but if anyone has a better solution I am all ears.
Thanks,
Chris Fernald
These are the rivets that mount the VIN tag to the dash in the left hand corner of the dash.
well if you want stock look your going to pay $40-50. I haven't seen them any cheaper.
I carefully squeeze the under side of the rivet . The nail will come out and you will be able to save them. Put a nail from a steel rivet in your factory rosette and reuse them I have done this several times . Its a little time consuming but works great. You can't get more original then that.
