buck351
I can't remember when or if I have ever replace the front rotors. Probably had them turned at some point. So I was wondering how you actually replace them? I thought I read somewhere that the lugs hold them on to the hub? If so how hard is it to take these off the hubs and will the process damage the lugs? I've never changes lugs before so I don't have any past experiance.
I've changed rotors on my Tacoma but they were bolted to the hub.
