What we're saying is that this one was already modified by the builder with the circled brush grounded.
Shouldnt have to change anything
Check the field as follows: Take a continuity tester (powered light, or an ohm meter). Place one lead on the field terminal and the other on the housing. It should light up, or measure between 2 and 4 ohms.
Then remove the circled brush. Retest the same way. It should not light up , or resistance will show as maximum or infinate.
The alternator pictured below was at some pointed hacked to make it an isolated field alternator.*
Who knows what it is now.
Test the rotor connections the same way as above.
*See the Identifying Chrysler Alternator thread for more info about how rebuilders hack alternators.
