Rubber tip on the brake rod
Princess Valiant
A.K.A. Rainy Day Auto
Colorado
When i removed the old master cylinder there was a small piece of rubber at the tip of the brake rod from the pedal that crumbled off. Not much of it was left.
Do I absolutely need it for a new master cylinder and if I need it, what is it called and where do I get one??
Thanks fabo
yes you do need it, it retains the pushrod!
dr. diff has em
edit to add links:
Fuel line will get soft and the rod will come out eventually and you will not have brakes, To install that rod you must remove it from the pedal under the dash. Install it into the master cylinder and pop it in place with force. You will not be able to get it out easy and save that ring. So if you have a boot and plastic cover put it on the rod first, usually if the rod came out that easy it had hose on it instead of the proper material ring. .
DO NOT use fuel hose. You don't want this brake pushrod falling out later in life.
The rubber piece gets installed on the brake rod frost, then pushed into the piston. It won't work the other way.
Damn, I guess I`m gonna die. I made my own pushrod too, I might die twice.
" there was a small piece of rubber at the tip of the brake rod from the pedal that crumbled off." Yeah that`s some good stuff.
I'm SUPRISED your not dead yet !!!! :poke: :rofl:
Worse your bad advise could harm someone else. If you want to do stupid **** go for it, but don't ncourage others then make fun of it.
Ever seen a pushrod fall out of the mat poster? Not a good day.
Anybody can take it or leave it. I`m not encouraging anybody to do anything.
:wtf: is a mat poster? As far as stupid ****... Get f**ked.
Dr. diff can keep them, 3 dollar part with $13.65
So $16.65 for a piece of rubber that fits on the tip of your pinky and that's if USPS doesn't lose it like lose everything else
Put the state in and recalculate. The shipping system on his website is not the best. Might be worth a call if that's what you want.
Its no secret that shipping costs nowadays are pretty outrageous, but even with the inflated shipping, its really not that expensive, especially to get a part that was made to fit and function properly. I also need one of these for my brake changeover, and Ill be buying a proper one rather than juryrigging some hose just to save a few bucks. Piece of mind is worth it :)
NOT needed for power brakes. The pushrod is captured inside the booster linkage.
As far as manual, in theory an inferior "retainer" grommet could fail and allow the pushrod to pull rearward and slip out of the hole.
Slipping out of the hole is rarely a good thing. I've never had that happen with a brake system even though I've parted out several old cars and found the grommet either hard as a stone, worn out or missing.
So under $20 to have the right part shipped directly to your door from an American run business that’s been supporting Mopars for decades, no effort needed on your behalf beyond a couple clicks. Nope, that’s crazy!
And we wonder why there aren’t more Mopar specific businesses making quality products for our hobby.
this thread reinforces two things:
1- people are cheap
2- always, always go over a car front to back after you buy it.
