[FOR SALE] Running 340/727 Setup $1500 or possible trade
Clovis, CA
Rating - 0%
0   0   0
Greetings,
Up for sale is a complete 340 setup - block casting number 2780930-340. Heads have casting numbers 3671587. Engine used to have headers on it but they've been replaced with factory manifolds that I'm not sure are original or not. Has Edelbrock aluminum intake and 4bbl carb, Mopar Performance valve covers etc. Currently mated to a 727 trans.
Condition - Engine and trans came in my Dart but I'm going a different route. The car ran and drove, but the transmission felt like it might need a rebuild. The motor seemed to run ok, but I'd recommend going through everything as it was in a car that sat for quite a while.
Asking $1500 for everything. Located in Central California. Pickup is preferred but I can put it on a pallet if you'd like to arrange shipping yourself. Would also consider partial trades for 8 - 3/4 rear end parts or A-Body disc brake parts.
You can PM me
Would you consider selling the column shift cross shaft and lower shift rod? Also the 4bbl kickdown linkages?
vin on engine?
Pass side pan rail about mid way back. Just below the block drain plug.
What disk brakes are you looking for? I have a complete 72' Kelsey Hayes small bolt pattern set up still on the car I'm looking to sell.?.
Something looks really odd about that year casting, never seen one flatted out like that!!! Can you provide the assembly stamp information from the pad under the drivers side head on the front of the engine please??
