[WANTED] Running small block near Las Vegas
Darter6
Nevada
My neighbor is looking for any running or ran when pulled small block 318/360.
His son has a 67 Dart that has been sitting for years and they want to get it running to sell it off.
Keep in mind that if you install a 318 or 360, you'll need a reducer bushing in the crank for the small button converter they have in the '67 and earlier 273. Also, you may run into exhaust issues, motor mount brackets, oil pan, and converter balance issues going to a 360. If his '67 is a manual trans car, make sure the replacement crank will accept a pilot bushing, or use the magnum version, which is a bearing.
Has a 727 from a later car. Had a Magnum 360 crate that they put in another car.
But thanks for the heads up.
