Evaporust is ok. It works good for a short time but it loses its effectiveness pretty quickly. That's been my experience several times and I'm stickin to it.
I agree, I did not say it did not work, it works great, but Evaporust will remove metal if it sits on it long enough.Evaporust works good for me
Doing the electrolysis with ANY chrome plated anything is terrible. A friend did some vise grips, and all he did was stick his hand in the water long enough to get them out, and then rinsed everything in soap and water, and it made him sick for days. Like, to the point that he refuse to use electrolysis ever again.Ill blast chrome right off a wrench too if you have it hooked backwards. Use the chrome wrench as the anode. I did a cylinder head as described and I didn't have much luck with it. Used SS as the anode.
Got a link? My search ended up with $76/gal ice cream machine cleaner.....?I have been messing with milkstone remover to remove rust. You mix it with water in a plastic barrel. Works nicely to remove rust. First soak the part in another barrel that has a mix of lye with water to remove paint. Picture is a rusty fan shroud soaked in milkstone remover. I had to mail order the milkstone remover. About $19 a gallon thru Tractor supply. I added 10 gallons of water to the 1 gallon of MSR. I ordered two gallons for the same shipping cost.
