Rust inhibitor
brian6pac
Legandary Member
Legendary Member
N.E.Ohio
What are you guys using for rust inhibitor in cooling systems when using just water, can't seem to find it anymore at parts stores around here.
Redline water wetter is available online from autozone. May be available at local store?
Redline Water Wetter
PRODUCT DESCRIPTION
Water Wetter - 12 oz, doubles wetting ability of water to reduce temps by up to 20f, rust and corrosion protection for reduced coolant levels or straight water, compatible with all glycol antifreeze, cleans and lubricates water pump seals.
  • checkmark-copy-6.svg
    Unique agent for cooling systems that doubles the wetting ability of water
    Rust and corrosion protection allows for use of straight water in racing or reduced antifreeze levels in warm climates
    Improves heat transfer and reduces cylinder head temperature
    May allow more spark advance for increase power and efficiency
    Use one bottle for most passenger cars and light trucks, treats 3 to 5 gallons or 13.2 to 15.9 liters. vehicles with larger cooling systems should use two bottles. small cooling systems should use 1 oz (3 to 4 cupfuls) per quart
    Compatible with new or used antifreeze (including DEX-COOLTM) and long-life versions) to improve the heat transfer of ethylene and propylene glycol systems.
Antifreeze.
I'm looking for some thing to run in my run stand, running distilled water and the inside of the blocks rust so bad so fast after you drain the water out is terrible.
I will have to look at the Redline Water Wetter
Antifreeze.
Yes, antifreeze mixed 50/50 with distilled water is the best protection your engine can get from corrosion, lubricate the seals, etc.
I still can't believe that people still fill their engines with straight tap water, regardless of the climate year round......
and it's relatively cheap
I used to run anti freeze but the last time my buddy was helping (it was his motor) and he didn't tighten the rad hose clamp and about 5 minutes into the breakin the hose blows off and made one hell of a mess.
My vote is for Dawn soap. Just make sure you record it and post it up on youtube.
:poke:
Okay, i'll bite.
Why do you use fabric softener on demo derby car?
It does the same as water wetter. Brings the temp down on the engine and helps keep it from boiling. Believe it or not those cars get so hot under hood they will melt a nylon oil line. If you have ever watched a good long heat or feature you will see the headers glowing orange with flames coming out of them.
Who would have thunk it?
How much percentage versus water do you use?
