[FOR SALE] Rusty Crusty Dent & Ding Sale
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
I pulled all these parts of the 67 & 68 Barracudas I am parting out. Prices + shipping from FL. Paypal F&F or PMO .
#1. SOLD. SOLD
Stripped the seats down to the frames. Has surface rust but not rotted though anywhere. Frames , seat backs and hinge hardware included.
$150.
#2
SOld. Sold
Seat brackets and sliders. Sliders move freely, the brackets are a little rusty on bottom and one has a hole rusted through.
All studs intact. $75
#3
sold. Sold
68 Power Steering Floor shift column. $125. Pretty clean and in good condition.
#4
68 Power Brake Booster Brackets. $30. Moves freely
#5
Rear seat parts . $25 for the lot.
Scroll on down for more parts. Claim parts by # listed ! Thanks for looking.
$50
68 V8 SB after cleaning I found some rust through .
Right front , needs a patch job.
#7
$50
67 V8 SB modified for BB. Good useable condition.
Note how it's squared off for the oil pan clearance and notched for the oil pump.
#8
Upper A arms good condition , will need new bushings and ball joint . $40 for the pair.
GONE !!!!!!
#8
Lower control arms. Good condition , will need new bushings also ! T bar adjusters moved freely.
$40 a pair.
#9
OEM 67 Dash pad. If you can use it, fix it up some .$50 All mounting studs intact.
More parts below ! Check em out .
All studs in tact. $40 Left side fender bling
#11
SOLD SOLD
$75
Deck trim. Not perfect ( but what is ) I will include a few of the clips I salvaged so you can figure out what is needed.
#12
$30 for the pair Crusty but intact.
#13
Fastback trim under side windows. Door trim has some small dings from removal 1/4 glass trim is ok.
$25
#14
$35 A little pitted but not terrible
#15
69 Tail panel . Has some dents and dings. Mostly on the upper & lower edges
$70
Thanks for looking , please claim by # listed . I can send more detailed pics if wanted.
Do you have any of the other power brake parts?
Is the pedal assembly different than a non PB one?
Thanks.
I don't know either, but the linkage sure is.
How about a booster?
Even a core.
I'm thinking about converting my 67 wagon to PB.
Pretty sure this stuff will work.
Thanks.
Even a core.
Yes I still have the booster core. PM me if interested in this stuff ! Make you a deal .
Mines a 70
You can buy them online. You may need to use your core. Finding a original one may be more difficult to find and more expensive. Also, they would be fragile and break easy as to crack. I never bought an aftermarket one, but I have seen some good ones and some bad ones. Do your research.
