S6 to v8 conversion bracket ?
FODOIMP
Bellmawr, NJ
Hi
Forgive my ignorance, but I am curious what makes the conversion brackets from slant six to v8 different between the 340/360 and 273/318? This is going in a 71 Duster.
yep the 360 has a different drivers side mount from the 318/340. i think you can make it work if you shim it. ive never done it, only read about it.
here is the left side 318 bracket see the plate i had to weld to fit on my 360,it can be done
