I've been doing quite a bit of outdoor sandblasting of large car parst with an old Tip portable blaster that has a 90-lb. pot, and using 30-mesh sand as the abrasive medium. My compressor has 10 hp. and is connected to an 80-gallon air tank.
With the 30-mesh, I find that a 1/8" blasting tip is the smallest I can use without clogging (I'm using a small tip so I can blast longer before having to wait for the compressor to re-charge the tank).
I've found that if I regulate the pressure down to 80 lbs. at the blasting pot, it still works well, I can blast longer than by leaving it unregulated (around 120 lbs.) and I don't get that big, wasteful blast of air containing no sand when I first open the blast valve, the way I do when I run it unregulated at the pot.
I've assembled an HF blast cabinet but haven't used it yet because I want to "do the mods" first and haven't got a round tuit yet. It will be nice to start using the cabinet for blasting smaller stuff because I will then be able to re-use the media.
So please tell me your experiences and words of wisdom about sandblasting!
Bill. re read your post. my 2 cents. 30 mesh (36 grit) is something i would use on a horrid semi truck frame (and i dont go that coarse). its not for automotive stuff. set it aside and find yourself some recycled glass. preferably in the 50-100 grit (45-100 mesh) or 30-60. 30-60 is the coarsest i go. 50-100 works great. its totally white metal. clean, no ghosting. i run. 30-60 grit and 40-70 rarely. 50-100 most of the time 100-200 for sheetmetal. your stuff will not be "peppered" and you dont have to open the valve so far to make it flow (saving some air)
#1 thing for good trouble free blasting is picking the right media as one media doesn't do every job well.
"sand" please stop using it. you already have heard the silicosis lecture i am sure but stay away please. and...sand sucks up more water. your making mud in your pot/flow issues
