[SOLD] Saturday Nite Parts Cleanout
RAT ROD AL
MOPAR ARCHAEOLOGIST - one parts hoard at a time!
Robbinsville, North Carolina
I have some more parts to clear out . Everyone should know the routine by now !
Claim parts by # listed. will combine shipping . Prices + shipping from Fl. 33956. Paypal F&F or you pay the fees. Thanks for looking !
#1
one 1" spacer sold... KrzyKuda.
1" & 2.5" sold...Dicer
$5 each 3-1" & 1 -2.5"
#2
Both housings sold... Steve..
34 tooth gear ...sold....plymouth67..
speedo gears $25 each . Teeth count marked on card board ! $5 each for the housings
#3
...sold Garret..
$7. Not sure which Holley this fits so I put the measurement there.
#4
...sold...j-anderson...
S/B 727 tube $10
#5
...SOLD KKuda
from 67 drum brake car. $30 May fit more.
#6
....sold..if3333
Heater control cables for non AC. 67 A body $15 all move freely.
#7
....sold Steve...
Not sure what Mopar this is from. Missing nut for the chrome bezel. $15 Other than that in good shape.
#8
Power brake booster assy. $45. It will surely need to be gone through and freashened up !
#9.......sold RightyTighty........
This one is in nice shape. Guy said it came off his 71 Dart with front disc.. Not sure of the M/C bore... # on M/C is DP33A
$60
Scroll on down for more parts and please claim by # listed.
67-69 notch barracuda rear side panels. good condition . will need paint. $25 for the pair.
#11
....sold... Kevin...
$15 8 hole plate.
#12
certicard sold OMR
Fuel pump eccentric, 3 drippers & trans line holder...sold Troy
$5 each
#13
...SOLD Steve..
New Remflex SB header gaskets. $20
#14
...SOLD... OMR..
4 and a half sets of SB header gaskets top pair looks like they were installed but not run. All others are new. $25 for the lot.
#15
318 oil pan gasket. $8
#16
Sold....
Massive lot of SB gaskets .. $50 for the lot
#17
lot of 2 440 valley pans with gaskets and 3 Valve cove gaskets All new. The metal trays have a light flash of rust from sitting around in an open box. $30 for all.
Thanks for looking Claim parts by # listed
Sign Me Up for #11 and I'll take the #16 Gasket Lot Also! (#11 I need the Gaskets for My Oil Adapter)
rt side oval type spacer is for starter. left side next to cooler line bracket is for older convertor cover. plate to inspect bolts without taking starter totally off.
could not find big cover in my parts cd but will look in reg parts book tomorrow. thinking they are same as they are just dust/rock shields. been too many beers ago. removing small cover allows person to drain convertor with out removing starter, braces, if equipped and shield. it takes a diff conv cover than normal.
