Mean416
Up for sale is an essentially new set of icon forged pistons. 4.070 bore 4.00 stroke. They were run through two heat cycles and I had to tear down the engine because of a cam bearing failure. There were other issues with the machining on the block and I ended up having to go up another size on the Pistons. They didn't use a deck plate when honing.
The Pistons are essentially immaculate. As are the rings. The rings have been gapped for use with nitrous or turbo.
This piston set without rings is going for over 800 right now:
https://www.summitracing.com/parts/uem-ic745-070/make/dodge
I'll take $600 for them.
