[WANTED] SB adjuster screw set
Just checked mine, 5/16 ball end.
Thought so. Some will say "no problem, running them for years .." They are not the same strength. The T/A rocker is obviously better. But you don't need them unless you are running a solid lifter.
TA rockers only fit TA heads.
T/A engines had some of the pushrod holes moved over in different locations than the standard small block head so they could be ported larger... I'm not sure the T/A rocker arms would work on the standard small block head because of the offset...
