[FOR SALE] SB bell housing -734
Mojack
Bristol, Tn.
Here's a small block bell housing in good shape 3515734. All threads are good with one starter thread a little shallow, see the pics, BUT I threaded it deeper and made a longer stud to engage deeper in the hole. It's good to go. There is a fork that can go with it for an additional $25 , it measures 10 7/8" long , Check out Brewers ad for the applications.
Bell alone $215
With fork $240
Plus shipping from Bristol, Tn. 37620
Thanks FABO
Bell housing Per Brewers site: 10.5″ small block bellhousing cast #3515734 to fit 1972-4 A-body (will also fit 1967-1971 A-body if BSB734 bellhousing ballstud bracket is used) and 1970-4 E-body (except 1970 with reverse lockout linkage) 318/340 3 & 4-speed applications, 4.354″ bearing retainer opening, uses 130 tooth flywheel.
