I want to confirm that the #2536563 intake will bolt to 318 heads, it came off 318 but want to confirm it fit without changing the angle of the holes. I assume it was a 273 intake.
Give me a min and I can look it upI want to confirm that the #2536563 intake will bolt to 318 heads, it came off 318 but want to confirm it fit without changing the angle of the holes. I assume it was a 273 intake.
That's a 66-67 273 intake.I want to confirm that the #2536563 intake will bolt to 318 heads, it came off 318 but want to confirm it fit without changing the angle of the holes. I assume it was a 273 intake.
Should bolt of 318 heads no problem, ????That's a 66-67 273 intake.
Yes. 64 and 65 was the oddball years for 273 intakes.Should bolt of 318 heads no problem, ????
