Yea Rick,cashwise a big block a body is faster and cheaper than a big block camaro now,if you stick to no billet silliness.
that's what I was thinking also! HAHAI have to admit being a Abody site the fact that the pole is 19/19 surprizes me?
I'm not sure off hand I was told they're KB's and the only numbers I found on the pistons came back to Silvolites (Hyperuetectic or however you spell it) they're nice flat top pieces SO to be honest they look like hyper's from the top but could be forgedWhat pistons? I have personally seen garbage 360s eith home pocket ported heads run low 12s at 110.You need to 9 to 1 ,worked Js of Xs.
I'll try to take a coupleDo not diss those pistons. I have personally seen a 175 spray hit to 7000+ ! If you can,post a pick of them top and bottom.A similar short block waxed my Rat.
I say a 400 b motor either with a 383 forged crank or stroked. There are many advantages to the large bore short stroke and the weight is not that much more. Drawbacks are exhaust is expensive, but so are quality headers for a small block, and engine mounts. At the power level stated in original post the cooling system and the rest of the drivetrain will cost the same.
a 400 ain't gonna happen there are none around here.. a 383 or 440 is it for BB'sIt's pretty simple, the short stroke B engine will turn some serious RPM with even stock parts and the right cam. Good parts and proper build you have yourself an motor that will spin 8k and like it. A lot of other advantages too. Distributor in front, external oil pump, water pump easier to service, have a better intake set up with no hot oil on the bottom of the manifold, can change cams and pull lifters without removing intake. I would say a 400 B engine with an overbore and you will be at 408 power level. Good heads and you will make more power as you can turn a lot more rpm with the short stroke and stil have good engine life.
why would you bother with a 383 crank when you can do a 440 crank? for a budget stroker build i mean...
not really into forced induction...Why not 360 with a nice big turbo or ProCharger?
71 Demon it's not a problem of finding them it's well the only 2 makers of BB A body headers are TTI and Schumacker OR you can buy flanges with 2" primaries that have 2" long stubs on them to make your own which is what I would do..I must of missed it but want car are you running that you can get BB headers for?
I find it funny most people on these forums tell you don't run a 273/318 run a 360/408 because there's no replacement for displacement but here it's run the smaller bad bore to stroke and rod ratio engine, get a 440 run stock stroke bottom end dump your money in the top end. You got to put a lot of money into sb short block to get it to 440 CID if you did the same to RB you'll have a 622 CID.
this is also on my mind as well 450 NA with a 100 shot would be insane fun in a street car...I have to say if I had a 360 short block with kb flat tops in it I would run what I had. I don't think I would shoot for 550 + HP. I would build the best combo I could that would have good life expectancy. I think you could get 450 hp that would live in a street strip car. Any more than that and you are going to run into drivability issues like hard to start in cold or wet weather, overheating in traffic, fouling plugs etc. High horsepower numbers are great on the track but seldom work well on the street.
