BillGrissom
Timing Cover Info for LA engines. Hope this helps someone.
I understood there were only 2 designs for LA engines (64-71 and 72+), but have run across 4 versions recently. Of course, Magnum engines have still another design w/ reverse rotation water pump (for Serpentine belt). I think either of the 2 water pumps (iron or alum) will fit on any of the 4 below (are there more water pumps?).
Photos:
'65 w/o timing tab (red)
'69 w/ integral timing tab on passenger side (water pump attached)
'72+ w/ integal timing tab on driver's side (shiny)
'76 w/o timing tab (yellow rust)
Details:
1965:
Original on my Dart GT 273 2-barrel
PN: D - 2128896-7 (note: "D" = ?)
Date Wheel (assume) w/ "65" in center & 12 month segments (assume) w/ 2 or 3 raised dots in some (meaning?).
1969:
Recent e-bay (can't find now). Never heard of a passenger's side integral tab before. Argue w/ the photo not me. The fuel pump location proves the photo wasn't reversed.
1972:
Purchased to replace my pitted 65 one. This is the most commonly seen, especially new. I think one can replace the crank seal from the front.
1976:
Installed on an extra 65 273 engine I bought recently. The original one probably corroded like mine.
PN 2128896 0914 12 "MADE IN CANADA", pentastar, date wheel with "76" in center. A separate metal timing tab was installed on passenger's side like mine. BTW, engine was rust-siezed. I pulled a piston out the bottom today and it is a raised Hi-Po w/ valve reliefs which matches local seller's statement that he removed a 4-hole iron intake and engine was special.
Note the '65 cover has an extra hole. Both 65 blocks have a tapped hole there. I filled mine w/ a setscrew and RTV. The other block had a sawed-off screw plugging it. I never read about this extra hole.
Note: most tapped holes in the block pass into either the water jacket or inside the engine (oil), so apply a good sealant to bolt threads. Ditto if replacing just the water pump.
I apologize if this info is redundant. I can't seem to search FABO well. If I search "timing cover" or "timing AND cover" it returns many, many posts (OR).
Photos:
Details:
1965:
1969:
1972:
1976:
