AR_Tech
Ran this cam in a 360 that I built. The cam has less than 5 hours run time. I am going a different direction with the build now. Asking $250 OBO plus shipping from central Arkansas.
Voodoo Solid Roller Cam. Good cam for high performance street or mild strip applications. Needs 2500-3000 RPM stall converter or 4-speed transmission, headers, 9.5:1+ compression ratio and 3.73+ gearing. Rough idle.
Part Number: 40200731
Previous Part Number: 60431
Jobber Price: $335.30
- Advertised Duration (Int/Exh): 267/273
- Duration @ .050 (Int/Exh): 237/243
- Gross Valve Lift (Int/Exh): .566/.578
- LSA/ICL: 110/106
- Valve Lash (Int/Exh): 016/016
- RPM Range: 2500-6600
- Includes: Cam Only
