[WANTED] SBP disc brake splash shields
rich7016
Active Member
Toms River NJ
I am in need of a set of SBP disc brake A-body splash shields. I'm in the process of doing a disc brake conversion on my 70 Valiant sedan. I have new hoses , rotors , calipers , pads , master cylinder , proportioning valve , spindles and wheel hubs. So , the splash shields are the only things I'm lacking to do this conversion. Thanks for your anticipated help
Folks will want to know what Disc Brake set up you are using.
Edit: Ooops, I missed the sbp part. Single pistons are bbp. :)
