I run the Scat stroker kit in my engine. Don't buy their kit balanced. They do a lousy job and won't give you your money back. Just buy the kit unbalanced and have a good reputable local shop balance it correctly. Also have your local shop check everything over; bearing clearances, crank run out, end play, etc.
